Check this...
Old Mar 11, 2003 | 09:36 PM
IROCBandit's Avatar
Check this...
A tech where I work has an engine for sale, only thing is its not put together, heres the specs
350 4 bold main - machined .030 over
crank polished - cross drilled @ 10 over
TRW flat top pistons - cast
Fel Pro full gasket set
486 Heads (ported)
Rering kit
valves ground
double gear timing chain, Clevete
High volume oil pump, Beaver
Holley Intake
Holley 600 4-barrel - totally reworked
Lunati 10 degree keepers
Lunati Valve springs
LT1 rods
mickey t - valve covers
accel hei distributor
bowtie cam and lifters - solid - 565 lift 3/4 cam
chrome fan assembly
is this worth $1800?? i don't have a HP calc, could anyone tell me what this thing might be pushing?
Old Mar 12, 2003 | 05:40 AM
ede's Avatar
ede
i wouldn't buy any cam that was missing 4 lobes and i would buy a cam or anything else from someone that refered to a cam as 3/4. the crank would be .010 under not 10 over, all in all it doesn't sound like a bargin to me and it has a lot of parts i wouldn't want, like a HV pump.
Old Mar 13, 2003 | 12:20 AM
IROCBandit's Avatar
your right man, looks like a no go
Old Mar 17, 2003 | 01:49 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
10 OVER WOULD BE A 400 CRANK. SOUNDS TO ME LIKE HE WAS BUILDIN A 383 STROKER. STILL WOULDNT BUY IT THO. YOU CAN GET WHOLE KITS FOR 600 AT ENGINEKITS.COM.
Old Mar 17, 2003 | 10:05 AM
NjCamaroCruiser's Avatar
sounds like someone is tryin to dump their mess onto you.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Blue419
Sep 10, 2015 01:03 PM
