ok I got the motor mounts off.. now what?
Old Mar 13, 2003 | 10:46 PM
jessek60's Avatar
everything on the engine is disconnected the motor mounts un bolted now where do i go....
first time here swapping a 305 tpi, for a 400
Old Mar 15, 2003 | 09:12 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Did you take the bell housing bolts off ??
you need to pull the engine toward the front then lift it up this way you do not damage the input shaft.
Old Mar 15, 2003 | 03:48 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i pulled the trans out with the motor. its easier to do it with the trans off though. other than that, you are ready to go. i would double check just to make sure everything is disconnected.
Old Mar 15, 2003 | 09:39 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
just did this last weekend. it's much easier to remove the tranny from the bellhousing(leave that on the engine). this will get the input shaft out of the way. don't forget to disconnect anything attached to the tranny first. I almost forgot the speedo cable. When pulling the engine make sure all sensors hoses etc are off. I forgot the clutch master cyclinder and had to unbolt it with the engine half way out and hanging from the hoist.
Just go slow and watch for anything that is catching and take pics so you can look back and remember getting rid of the 305.
Old Mar 17, 2003 | 01:30 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
TAKE YOUR TIME IF YOUR DOIN IT BY YOURSELF. I WAS ALL EXCITED AND WORKIN ON IT LIKE NASCAR THEN THE CHAIN HOLDING THE MOTOR SHIFTED AND BROKE STUFF. EXCITEMENT WENT TO 0 AND I DRANK MYSELF TO SLEEP. SO GET SOME FRIENDS OVER THERE TO HELP YOU AND BRIBE THEM WITH BEER AND FOOD IF YOU HAVE TO. GOOD LUCK BRO.
Old Mar 17, 2003 | 10:14 AM
smokingss's Avatar
ahh, i remember bribing my friends with beer to phisically remove like 7 coats of paint off one of my cars...a 30pack and two drunks have way too much fun with screw drivers and power tools...poor car...oh well
Old Mar 18, 2003 | 01:01 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Ah, the good ol' days,
Old Mar 18, 2003 | 03:46 AM
Car: FBODYS
Engine: ALWAYS 8'S
UNDER PAID HELP
I DONT SEE ANY PAYMENT FOR THE MAN. ABSOLUTELY NO BEER CANS. SHOW ME ONE ILL BE HAPPY
Old Mar 18, 2003 | 06:22 AM
EvilCartman's Avatar
Car: '82 Z28
Problem with turning off your caps lock?
Old Mar 18, 2003 | 03:28 PM
Zepher's Avatar
Re: UNDER PAID HELP
Pepsi and pizza is all it cost me.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
