Help identify this engine please!!!
Old Mar 15, 2003 | 11:48 PM
cchris0411's Avatar
I am looking for a few people out there who really know these cars. I recently bought a complete engine, wiring harness and ecm from an out of business engine shop.. Here is my problem.. I need to know the specific year or pretty close to it to get correct parts for the engine... Ok to make it eventually run..
This is what I know about the engine: It is a 305 (high out put not sure??)
Block numbers: 14093627.. on the side of the bolck it is stamped 627 The top of the block says GM 5.0LG SGI
The ECM unit's numbers are as follows: 1227165..........869461...M611161247
The valve case covers have the bolts not in the middle but outside of the covers.
The distributer has the "coil" mounted on top...
I am looking to purchase a painless wiring harness and possible a better cam for the engine..
Thanks guys!
Christopher
Old Mar 16, 2003 | 12:53 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
14093627 is a 1988-1995 305 block. Get the suffix code off the block. It's stamped into the pad in front of the passenger side head.
Talk to your local GM dealer about the ECM numbers.
Old Mar 16, 2003 | 01:05 AM
cchris0411's Avatar
Re: Help identify this engine please!!!
I think the suffix code on the engine is as follows:
I tlooks like an upside down "T"then 120
Old Mar 17, 2003 | 01:40 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
87- 91 305 2 BOLT MAIN , ROLLER CAM, 1 PIECE REAR SEAL. USED IN GM G BODYS AND F BODYS. EARLY PRE 80 HEADS NOT ORIGINALLY ON THAT MOTOR
Old Mar 17, 2003 | 10:04 AM
smokingss's Avatar
heads can be 80-86, centerbolt heads were used starting in 87. to get dates of the heads, get their casting numbers as well
Old Mar 17, 2003 | 10:47 AM
cchris0411's Avatar
Head numbers?
I looked on the heads for a number but did not find one.. COuld you let me know whee to look..
The only number I found was on the back of the head and it was 64..
Thank you guys soo much!
Christopher
Old Mar 17, 2003 | 11:12 AM
smokingss's Avatar
ah yes , i forgot to mention that part...the casting numbers are on top...under the valve covers, just remove the four bolts and the cover comes off, now is a good time to see how the engine looks in there and to replace valve cover gasket anyway....heres a pic of a 350 head i had laying around off..this is a centerbolt head but gives you the idea, the numbers run along on the inside, im pretty sure its the same with the stampings on your heads. Once you have those numbers, im sure someone can tell you where you can decode them.
Old Mar 17, 2003 | 01:45 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
1227165 ECU is MAF. Depending on what year car the engine is out of, it is $32, $32b, or $6E code (This doesn't matter unless you are going get into prom programing)
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
