Caprice 350 non-LT1??
Old Mar 17, 2003 | 05:44 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
There's a 350 out of a '96 Caprice at the local salvage yard. The guy said it's not an LT1, it's just a 350. I looked at it, and it looks like an LT1. What's the difference between a Caprice 350 and an LT1? He said he wants $850 for it, everything's uncluded(computer wiring harness, the works). I think I can talk him down to $750 or so. Is that a good deal, or should I not waste my time. What's the aftermarket like for a Caprice 350? Do they use some of the same components as the LT1? Thanks
Old Mar 17, 2003 | 08:42 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
make sure its not a 4.3
a number of 4.3 V8 cars were made to commerate the 40th anniversary of the small block chevy
could very well be a 4.3 that he means by it NOT being an LT1
the 4.3 was known as the L99
Old Mar 17, 2003 | 09:33 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks, how do I make sure it's not a 4.3 liter? But, if it is a tru 350, is it that much different than the F-body LT1? Is it worth getting and modding?
Old Mar 18, 2003 | 04:01 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
Sure there is a difference, about 20 horse and torque . I think the reason for the difference is the different cam. 4.3 v-8's (265c.i.) were dogs in Impla's but were used because the first small block chevrolet introduced was a 265c.i. engine (and had the same bore and stroke).
Later, Garrett
Old Mar 18, 2003 | 09:06 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Ok, so aside from the 4.3 liter in the Caprices, was there an actual LT1 engine in them (with iron heads of course)? Or was there just the 4.3 liter LT1's in the Caprice? This guys says it's a 350 out of a '96 Caprice. He said it's not an LT1, because it doens't have aluminum heads like the F-body's do. So, if it IS a iron headed-LT1, would it be worth $750?
Old Mar 22, 2003 | 11:07 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Anyone? We're goin' to look at it on Monday, and I'd like to know as much about it as I can. What should I look for? THanks in advance
Old Mar 22, 2003 | 11:23 AM
Car: 1991 Formula
Yes there was an LT-1 in the Caprices (I think maybe only Police cars but I'm not sure) I know they were in those cars, they were rated around 15-20 less horse than the F-body L-T1's.
Yes the LT-1 is worth $750 if it comes complete with acc. and computer.
Later, Garrett
Old Mar 22, 2003 | 08:22 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Only real way to tell what the hell it is the casting number!
Old Mar 23, 2003 | 04:59 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
I read somewhere that if it was a 4.3 liter, "4.3" was stamped on the block somewhere. Is this true? Also, if I get the VIN number off the block, where can I decode it to see if it's a 350 LT1? Thanks,
Old Mar 23, 2003 | 05:25 PM
www.mortec.com
Old Mar 25, 2003 | 08:40 PM
Keith27's Avatar
Look at the 8th digit in the vin.......LT1 is a "P". They also put the "P" motor in the Buick Roadmaster.
Peace
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
88rscamar0
Sep 23, 2015 09:08 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Strick1
Sep 6, 2015 10:38 AM
Formula_88AE
Sep 3, 2015 01:47 PM
