'88 IROC-Z 305 T.B.I - '88-'90 350 T.P.I Conversion
Old Mar 18, 2003 | 07:15 AM
CustomCarShop's Avatar
TBI - TPI Swap Question? Please HELP!
I have read up all the other postings on doing this swap? I have an '88 IROC-Z 5.0 T.B.I. I plan on buying a '88 - '90 5.7 T.P.I Donor car. I kow the basic things to remove off the car, obviously the engine, wiring harness, ecm, fuel pump. Everyone says to go look at the tech article? And theonly Tech Article I see is converting a 90-92 T.B.I.
But what else should I take off the car that I will need for the swap? I have read some poeple have even changed dashboards and even the fuel lines on this conversion?
Could someone give me a full list of every thing I need from the donor car, anyone that has done this Swap that knows any of the little things aswell?
Thanks....
:rockon:
Old Jun 4, 2007 | 06:45 AM
IROC BxR's Avatar
Re: TBI - TPI Swap Question? Please HELP!
I NEED TO KNOW THIS AS WELL, I'm trying to swap my 88 iroc into a 89 RS. What all do i need to swap out? suspension? rear end? please help
Old Jun 4, 2007 | 07:26 AM
IROC BxR's Avatar
P.S. how long would it take with proper tools to transfer all the things i need to from my 88 IROC into my 89 RS?
Old Jun 4, 2007 | 09:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by CustomCarShop
I have an '88 IROC-Z 5.0 T.B.I. I plan on buying a '88 - '90 5.7 T.P.I Donor car. I know the basic things to remove off the car, obviously the engine, wiring harness, ecm, fuel pump. Everyone says to go look at the tech article? And the only Tech Article I see is converting a 90-92 T.B.I.
Well, this is pretty old. Sorry it was never answered.
Throttle cables are the only other things I can think of.
VATS may be an issue, depending upon the donor & receptor years.
TPI cars tended to have a slightly better suspension & gearing, but changing springs/swaybars/transmission/diff aren't "required".
Old Jun 5, 2007 | 04:07 AM
IROC BxR's Avatar
okay, but wich parts of those are the same, i was looking at the RS and IROC. WHAT parts are different mechanicaly from an 88RIOC TPI w/ 350 tpi and the 305 TBI 89 RS????
Old Jun 5, 2007 | 12:32 PM
five7kid's Avatar
ECM, fuel pump.
Everything else you can see, if you've got both vehicles side-by-side.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
