timing problem
Old Mar 23, 2003 | 04:30 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
timing problem
ok did motor swap 305-350 well running rough, friend said check timing , he said disconect brown wire from ignition module the shine timing did not see brown wire from module only ignition coil is this the same?
well can some tell me exactly how to time it.
92 rs
Old Mar 23, 2003 | 10:30 PM
Guest
Guest
Posts: n/a
Check over by the AC box, you should see a tan wire with a black stripe and a single weatherpack connector. Take that apart, then set your timing. Dont do it otherwise, because the computer does adjust the timing at idle.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
