Poor Highway Gas Mileage LT-1
Hello Everyone,
I am experiencing very poor highway gas mileage. However city driving seems great.
I am running a LT-1, engine, tranny and rear-end all from the same car. It is from a '95 Z-28 with 3:23 gears. It is an automatic.
A few notes.
I do not have a catalytic converter installed and the air pump is not hooked up.
That is not really by choice, because I do want to pass emissions. However, it was easier to leave the cat out for now and I am missing one hose for the air pump.
I assume the tranny is working properly. I think 4th gear is actually the electronic overdrive? Is that correct.
Thanks Again,
Gus
A few notes.
Thanks Again,
Gus
Car: 1987 Trans Am
Engine: Lt1
How does the motor run overall? Smooth-rough? You may not be getting enough air-flow in to the motor. I had a '95 Formula with essentially your same set-up except for I added a Trans-go shift kit which didn't effect the gearing but I had excellent high-way mileage. Yes, 4th gear is OD by the way. Do you have all 4 gears? Try starting from a dead stop and accelerate modestly up to about 70mph and count how many times it shifts to make sure you are getting into 4th.
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Sounds like you should use autotap or LT1 edit to see what's going on. I suspect it may be running in speed density mode.
what do you consider bad gas mileage? I'm getting around 16-19 around town, and usually average around 25 on the highway. I also have no cat or air injection. or EGR for that matter. In fact I have no emissions equipment what so ever on the engine. like wm_sorg suggested, sounds like it could be Speed Density mode.
Estimated 12miles per gallon
I have not hooked up the odometer so I am estimating 12miles per gallon highway.
From the wiring diagrams the ALDL connector appears to have 2 important wires. The others are postive reference/power or grounds. Any experience with wiring in an ALDL connector?
I have a scan tool if I can get a read out connector.
Thanks Again,
Gus
Thanks Again,
Gus
Car: 1985 Camaro Z28
Engine: Caprice LT1
Only a few important wires for the ALDL.
The ALDL signal wire, a diagnostic wire and a ground.
For programming I only needed to hook up the aldl wire and the ground.
MikkoV
Sep 9, 2015 04:25 PM
