every thing needed for 350 swap
Old Apr 13, 2003 | 10:41 PM
fbodyandy's Avatar
if some one could give me a list of EVERYTHING i would need to swap my 305 to a 350 in my 91 rs camaro with the 5 spd.
Old Apr 13, 2003 | 10:43 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
350 (duh)
knock sensor
PROM from a 350 TBI equipped b-body (caprice, road disaster)
might need bigger injectors (not sure on this- check with someone who knows for sure)
Old Apr 13, 2003 | 11:34 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
More Specifically:
Knock Sensor: #10456288
ESC Module: #16128261
350 Truck Injectors (should be big enough, unless it's cammed big) #17112493 (2 required)
The Caprice (B-Body) chip works for automatics, since yours is a 5 speed (mine too) you should have a custom chip burned.
-Rich-
midge54
Sep 2, 2020 07:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
armybyrd
Aug 10, 2015 09:23 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
gwade12
Aug 8, 2015 08:17 AM
