Salvage Yard 350 I Found -- Compatible?
Old Apr 18, 2003 | 09:27 AM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
My dad was looking through a salvage yard and saw an engine with "5.7L" stamped on the back of it. So he took down the casting number which was 10243880. We checked this at a number of places and it gave us:
"10243880...350...'95-'00...2 or 4-bolt...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal"
What exactly does this mean? Will this work in my '91 TBI RS (I was thinking of putting a carb on it)? I mean, I'd imagine it would.....but I was just double checking. The guy wants a hundred bucks for it...so I think I'll just go ahead and take it.
The heads on it seem to be L98 heads with a casting number of 14096217. When I checked this number I got:
"14096217...55-86...350..........Crate motor, 285hp/300hp, 64cc chambers, 72' or 90' center intake manifold bolt angles"
I checked another place and got:
"SBC Cast Iron L98 Center Bolt Valve Cover Head. This is a cast iron cylinder head assembly used on 285 hp 350 engine (P/N 12353641). This complete cylinder head assembly includes 1.94" intake valves, 1.50" exhaust valves, valve springs (P/N 3901068) and valve spring caps (P/N 14003978).
Technical Notes: This cylinder head has 64cc chambers. The cast number for this head is P/N 14101083 or 14096217 . This cylinder head has 1987 and later inlet manifold bolt pattern. The center two bolts are at a 72º angle."
Any issues I'm gonna have with this?
Old Apr 18, 2003 | 12:43 PM
1986redbird's Avatar
that motor should be a direct bolt in, I'm sure the heads will be fine on the motor but I'm not sure about the potential of them (performance wise). the 305 tbi will probably be bottleneck for performance on that motor,hell it is on the 305. I think there are some mods you can do to the tbi to increase performance.
there should be no other problems, the flywheel,and intake from your car shoulb bolt right up no problems.
if your really lucky it's from a low milage wreck and you can clean it up and run it like it is. if not it still isn't that expensive to rebuild it.
P.S. if it still has the ZZ4 cam in there it should produce good power.
Old Apr 18, 2003 | 02:28 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Get it. NOW - 350 roller blocks are sum good and $100 is a good price.
Old Apr 18, 2003 | 07:29 PM
demonkey36's Avatar
Car: 1991 Camaro RS
Well....as my luck would have it, the guy sold it 3 days ago and never told me.
Old Apr 19, 2003 | 04:13 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
not suprising
Old Apr 19, 2003 | 10:52 AM
Camarothunder85's Avatar
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
Man, that sucks. What yard was it at?
Old Apr 20, 2003 | 07:50 AM
demonkey36's Avatar
Car: 1991 Camaro RS
Not telling......that's MY secret...
A place out in Kissimmee...called Preston's Auto Parts & Salvage Yard. PM me if you want the number or something.
nuggie
Aug 25, 2015 01:27 PM
NinjaNife
Aug 23, 2015 11:49 AM
bjpotter
Aug 12, 2015 06:06 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
antares57
Aug 6, 2015 07:47 AM
