V6 front springs?
Old Apr 20, 2003 | 04:55 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
V6 front springs?
I am taking a 2.8 FI out of a 85 camaro and replacing it with a mild 370 horse 350. I am still running the 700r4 and stock v6 rear (3.42s). My question is do I have to change front springs? I been told if I use the v6 it will lift real hard on take off. This will be a weekend cruiser and Bracket ET car. Shooting for low 13s. What else will have to be swaped? motor mounts I know but does the v8 donor car I have have bigger brakes? etc...?
-Terry-
Old Apr 20, 2003 | 05:09 PM
indy82z's Avatar
I ran V6 springs in one of my old 82's and it lowered it about 1 1/2 inches. Never had a ground clearance issues. They will help with weight transfer. Brakes are the same. The frame mounts are the biggie. Radiator will need swapped as will about a hundred "little items" so keep the donor car handy. I believe the V6 tranny is different and will not bolt up to a V8..and if it does I really doubt it will last long....
Tom
Old Apr 22, 2003 | 12:21 AM
firestarter's Avatar
Car: 86' camaro s/c
Engine: 357
Transmission: th350
you need a v-8 tranny. The bolt pattern is different.
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
