can i use my 700r4 trans with an lt1 or ls1 swap
Old Apr 21, 2003 | 08:32 PM
jbonz28's Avatar
well can i? and can you guys just give me a list of everything i'll need
Old Apr 21, 2003 | 09:13 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
LT1 yes
LS1 i dont believe so, because of a slightly different bolt pattern, and i'm not sure if the TC would mate up to the flexplate
Old Apr 21, 2003 | 09:48 PM
TexasLT1's Avatar
Car: '92 RS
Re: can i use my 700r4 trans with an lt1 or ls1 swap
no because everyones swap is a little different and everyone I know of has done things a little bit differently. just search through the LT1 swap posts and you'll get a good idea of what you'll need.
Old Apr 21, 2003 | 09:58 PM
StealthElephant's Avatar
Car: 87' Iroc
You CAN do anything if you fabricate enough stuff.... Why do it the easy way when you can simply custom make everything
Old Apr 21, 2003 | 10:21 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Originally posted by StealthElephant
simply custom make
I tend to see that as an oxymoron
Old Apr 21, 2003 | 11:26 PM
Momar's Avatar
very much so, but it is nice to be able to look back and see what you have accomplished sometimes. I wouldn't think it would be worth it to use the 700R4 behind a LS1, but if thats what you have you can use it on a LT1 if you use a 93 Throttle body.
Ben
1984HO
Mar 19, 2021 11:59 AM
midge54
Sep 2, 2020 07:13 PM
camaro11j
Sep 19, 2018 08:49 AM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
