2.8 for 3.4 swap
Old Apr 24, 2003 | 10:48 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
Transmission: 700 R4
2.8 for 3.4 swap
Hi again... Ok I asked before if I could put a V8 in my 1989 Firebird which has the stock 2.8 V6. From what I ahve been hearing I can drop a 3.4 V6 in it no problem. And I don't have to change the computer or wiring harness. Is this true? And how much work would it be for a one man job. Basically I have around 500 to 600 hundred dollars to spend on the whole thing. I am trying to see which way is the best way to go. I all around would like to get some power out of my car. Any ideas or suggestions would be greatly appreciated. Oh and the only dilemma I have is that I don't have a engine stand either.
thanks
Old Apr 24, 2003 | 10:55 AM
Zyddian's Avatar
Car: 84 Firebird
Engine: V8 383
I forgot to mention that it has the crossfire fuel injection. I don't know if that's important or not.
Old Apr 24, 2003 | 12:13 PM
Parrydise7's Avatar
You might have better luck if you post this on the V6 board. Also, there is a tech article on this. You might want to take a look at that. I replaced the 2.8 in my Jeep with a 3.4 and the swap was fairly simple and a lot easier than a V8 swap.
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
