Removing a siezed Engine
Old May 2, 2003 | 12:39 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
I threw a Rod on my V6, and I want to do a Very easy swap to another v6 till I can afford my iroc
anyway, Its all siezed up, and the flywheel cannot rotate. We need to inorder to disconnect the tranny... I dont want to pull the tranny with it. My shop teacher told me a way that sounds wierd and I wanted to know if anyone else thought its a good Idea....
He said we could unbolt the 6 bell housing bolts and the engine mounts and whatever else on the engine, and then lift it just barely enough to get the engine over the steering, and then support the tranny with a jack, and lift engine, and slide it forward and the torque converter will just slide off the tranny and come out with the engine. It should spill ATF everywhere.
Does this sound like it will work to anyone else? My shop teacher is really smart, and he is sure it will be a good way.
Thanks for any opinions
Old May 2, 2003 | 01:37 PM
ede's Avatar
ede
yeah it'll work, people do it every day like that
Old May 2, 2003 | 09:49 PM
Car: 95 Z28
So the torque converter just slides off easily? Or do I have to unbolt something there too?
Thanks!
Old May 2, 2003 | 09:55 PM
1986redbird's Avatar
yeah the torque converter just slides on the tranny. and it will spill alot of fluid so be ready.
Old May 2, 2003 | 11:23 PM
Car: 95 Z28
cool. This means I can probally have my camaro working next week! I am happy! THanks
Old May 3, 2003 | 08:45 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
u could also remove one of the heads. have someone with a ratchet with a big pole on it turn the crank while u beat the piston down with big pipe and sledge.
atleast thats how i did it
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
