Engine swap to carbed built 350...please advise
Old May 11, 2003 | 09:35 PM
USAF_Maro's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=178437
I orignally posted this is the general section, I just noticed this section. So what do you guys think?
USAF_Maro
Old May 12, 2003 | 02:17 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Those guys there are on the money for conver stall speed. I would go the low air cleaner as well.
If you are worried about your converter feeling too loose check out a yank SS3600. They have the tightness and efficiency of a 2600 stall and give you the hard hiting STR of a 3600. Best of all is is 29LBS! Stock is 55. Of course it will set you back a few more dollars, but well worth it in my opinion.
Do not forget gears also play an important role in your selection. I did not recall seeing any trans or gear specs on your other thread.
Old May 12, 2003 | 10:31 PM
USAF_Maro's Avatar
I will look for the YANK, for now the stock 700r4 with non-posi rear will have to di until I can get different.
USAF_Maro
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
