LT1 starter... does it need shims?
Old May 22, 2003 | 08:22 AM
bluepastu's Avatar
Car: 87 vert
Just installed the LT1 and am using the LT1 starter. When I start her up there seems to be a winding noice. Is this common on the new lt1 starters or do I need to shim the starter?
I'm using the T5 trans with a RAM clutch(didn't think this info was needed).
any info would B great.
Old May 22, 2003 | 10:21 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Most starters use shims. Check the clearance between the flywheel gear and the starter gear. If they are meshing to tightly, you need a shim. Sorry I don't know what the clearance spec is.
Old May 22, 2003 | 12:57 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I didn't use a shim but then again, I have a t56 with my Lt1 and haven't had a problem yet. If there is a close by GM dealer(doesn't matter which one), slide by their parts department and ask them to see a diagram.
Old May 22, 2003 | 03:58 PM
TexasLT1's Avatar
Car: '92 RS
I used the T-5 with the LT1 and starter, didn't need any shims...
Old May 22, 2003 | 11:10 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
what about the T-5 with an LT1 but a 91 starter?
Old May 23, 2003 | 08:34 AM
bluepastu's Avatar
Car: 87 vert
TexasLT1, dwhen you crank the LT you doen't hear a winding noise(i'll last for like half a second - the LT1 fires up). I'm just curious because I wouldn't want to have to buy another starter in a couple of months when it's brand new from GM.
Thinking about taking it to a dealer.
Old May 26, 2003 | 10:28 AM
mat89RS's Avatar
Are you sure this whinning is not comming from the gears that drives the optispark and the waterpump ??? because they're is some obvious noise from that on all lt1 engines.
Old May 28, 2003 | 01:58 PM
bluepastu's Avatar
Car: 87 vert
no, this sounds like it's from the starter. it's a dominating sounds from the underneith.
(i know this is a seperate question/issue)
When I first start driving and put her into first. the car vibrates(but not when I shift into the other gears). then sometimes when I come to a complete stop(or stop light) it'll stall. And when I turn the car off - I smell buring(almost like to smell of old or rotten eggs). what's up with that?
88SS6SPEED
Nov 11, 2015 07:05 AM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
dimented24x7
Sep 17, 2015 06:58 AM
FormulasOnly
Sep 10, 2015 09:07 PM
