lowering engine in motor in mounts ?
Old May 29, 2003 | 11:01 PM
P170412's Avatar
Hi,
I am looking for a way to lower the engine at the motor mounts by about 1 inch. Here's the deal.
I swapped in a 383 with an aftermarket T-56 and a ford 9" (4.11's) into my 88 3rd gen. Spohn torque arm and trans mount. I can not get the drive shaft angle correct to eliminate vibration which starts at 65 mph.
I have raised the transmission until it hits the trans tunnel, after trimming unneccessary aluminum from trans housing. I have raised the car back up to stock level and still can not get a 0* angle at the tail shaft. Even with 2* negative at pinion.
I know others out there are successfully runing similar combinations. Any advice would be greatly appreciated.
Old May 30, 2003 | 11:14 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
There really is not much wiggle room in terms of lowering the engine. I woud concentrate on trying to correct the problem with the rear. Some angle on the shaft is normal. The trans and pinion angles have to be paralell.
jhawkeye
May 25, 2022 06:33 PM
italiano67
Dec 11, 2016 09:21 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
