swapping tips
Old May 30, 2003 | 03:16 PM
stroken_camaro9's Avatar
Car: 92 camaro rs
Transmission: th350
swapping tips
can anyone tell me what is going to happen when i swap my 305 with a 383. am i going to run into any major problems or should everything just bolt up. its a 305 TBI out of a 92 camaro. and i'm putting in a carb. 383 from a 78 chevy pickup. also if i bought a powersteering pump for that 78 pickup will it hook up to everything in my car just fine?
Old May 30, 2003 | 04:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The external balancing of the 383 is going to cause you the most headaches. Most externally-balanced flywheels/flexplates are 168 tooth, which causes issues. I hope you have exhaust upgrades planned. And means to handle the additional power.
Buy accessories for the chassis, not the engine. If you need a power steering pump, get one that's an original replacement for your car.
Old May 31, 2003 | 08:55 AM
Car: 92 camaro rs
Transmission: th350
how would i make the one for my car fit on the new motor?
Old May 31, 2003 | 10:06 PM
MCas7's Avatar
All of the accesssory brackets will bolt right on to the new engine. They are the same block and the bolts on the heads should be in the same locations as the 305.
Old May 31, 2003 | 10:31 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Depending on the power of the new engine, you may have to upgrade the fuel system. The 3/8" lines may not be enough. If you use the stock pump, you have to rewire it and get a regulator. If not, obviously you have to drop the tank or cut behind the seats. The stock fan probably won't be enough, I would get the dual fans. If you use a clutch fan you have to figure out how to mount it on the serpentine crank pulley (I'm assuming you won't be using the '78 accessories, if you do it'll cause a lot of issues). That's all I can think of right now..
Old Jun 1, 2003 | 08:27 AM
Car: 92 camaro rs
Transmission: th350
i do have a regulator. and are u saying that a 78 350 block and a 92 305 block are the same thing for a power steering pump. and is it hard to change out fuel lines?
Old Jun 1, 2003 | 10:21 AM
MCas7's Avatar
The block has nothing to do with the power steering pump. The only thing that has to be the same is the mounting holes in the cylinder head and the block. And yes they are in the same locations. Fuel lines are pretty easy to change. Where are the ones that you need to change?
Ghettobird52
Apr 21, 2020 08:44 PM
Warlocksirix
Sep 3, 2015 12:26 PM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Hello, Michael
Aug 20, 2015 03:19 PM
