will my current Exhaust fit?
Car: Trans Am
hey all im getting a smashed up 86 camaro with a 305 tpi to do an engine swap into my 86 2.8 firebird, the prob is that the camaro has no Exhaust will the birds Exhaust work with the bigger engine? i will get it upgraded later when i have some more money but will it work for now. oh yeh the birds Exhaust is a single to the muffler then with dual tips from that, thanks
Car: 4
Engine: 6
Transmission: 5
I'm sure you could "alternate engineer" some means of connection between the motor and the little 6-cyl tubes. However, if you mean "will all my exhaust fit through that system", then no. You will have a tough time cramming 5 liters of exhaust through a system that chokes on 2.8 liters.
I would not spend money at the mufffler shop to half-*** it that way, as cheap as an entire cat-back exhausts are from Edelbrock or Blowmaster or Dynomax or Hooker etc. That would be using your own money as the ammunition to shoot yourself in the shorts with.
Transmission: 4L80E/4L80E
The bolt-on aftermarket exhaust systems out there (headers, y-pipe, cat, cat-back) for your donor car application is the one we "others" use to upgrade ours.
Street Lethal
Apr 30, 2019 12:14 PM
ambainb
Apr 25, 2016 09:21 PM
but what about everything else?
