1988 TPI setup onto 1985 carb block... possible?
Old Jun 23, 2003 | 03:04 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have a 1985 Chevy Caprice Estate wagon taht has a 305 carb engine... I am getting bored with just working on the 'maro (don't worry, I still will!) and was wondering if this setup I have laying around will work; here's my idea:
1988 Tuned Port Injection setup
1985 305 4 barrel engine
fast
Can I just swap intakes (of course the wiring too, but that is covered... Painless makes a conversion harness) and be done with it, or will the intake not fit/work on that block??
Thanks guys, without you I'd tear apart a car and be stuck!
Old Jun 23, 2003 | 06:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Fit" - yes.
"Bolt right on" - not quite. At the very least, you'll have to do something about the center two bolts on each side of the intake manifold. They changed angle in 1987.
You'll also need sensors, ECM, etc., but I assume you knew that.
"= fast" - We all have our dreams. It'll probably be faster with the carb after you fix the exhaust, cam, air cleaner, and head issues that really make the LG4 slow. TPI won't solve any of those (except possibly air cleaner).
Old Jun 24, 2003 | 06:20 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, so can I mod the intake or should I get different heads? I'm on a tight budget, but I'm tearing down my 1988 roller moter... it spun a crank bearing...
Can I possibly use the heads from it? It's the 305 TPI with the hotter stock cam...?
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
