305 tbi to 350 carb
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
305 tbi to 350 carb
OK, in my 1991 RS 305 5,speed. I burnted a piston ring, and my computer system was going hay wire, so i got a 350 roller motor from my brother(Momar) and we rebuilt the shortblock. I have a 750 holley vacuum secondaries, and a vacuum advance distributor to put on my car. L98 Manifolds, Y-Pipe, and I-pipe. I am using a factory quadrajet intake with an adapter, to get the car running i am going to put my stock heads on there, until Momar changes his heads to his vortec heads he has. Then i am going to put his ported LG4 heads on it. Today i was going threw, and i was cutting out diffrent peices of the wiring, and I was wondering, i have cut all of the wires, except to my transmission(VSS). And to my sensors for the gauges, and my cooling fan. I was wondering because my friend said my gauges wouldnt work if i did that, but i had already cut all of the stuff out of the harness. So are my gauges going to work?
Desktop dyno also say i should get about 251hp and 431tq and i was wondering if that would be accurate, since i have an LO5, which would be the same cam as what is in a LO3.
Thanks in Advance
Levi Brohez
Thanks in Advance
Levi Brohez
I got rid of my air conditioning, and my smog pump, and i was wondering what belt to use, i still have the tensioner pulley from next to the A\C. so what belt legnth will i need?
Thanks in Advance
Levi Brohez
Thanks in Advance
Levi Brohez
doesnt anybody know, i am going to put my a/c back on, just not hooked up, and i am going to run a 268k6 belt on it,
Some body has to know the awnsers to my questions.
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If you saved the remnance of the harness you cut, you can easily repair it. There is no way of knowing what will not work unless you know exactly what you cut from the harness.
As far as the belt goes you should try to measure it to see what length you need. I think there was a pully available for eliminating the somg pump, but I am not sure.
