Finished 305/Auto to 406/6speed Conversion!!!
Old Jun 30, 2003 | 02:04 AM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
Transmission: 6 speed
Axle/Gears: Strange 12 bolt 3.73
Well its finally done I have been waiting for years to do this to my car. I have pulled out the original 305 H.O. Motor and 700R4 and trasplanted a fully custom built 406ci motor with a Lt1/T56 6speed transmission. The project was pretty straight forward to begin I bought another 1984 Z28 that was a factory 5 speed 305 car. I did this to make sure that my swap was as trouble free and factory looking as possible. I was able to cut a hole in the floor and firewalls in the exact size and location as the factory five speed car. I also swapped all needed brackets, wiring harness, console pieces and shifter boot, the pedal assembly even the steering column from the 5speed car. The next tricky part was the bolting of the transmission to the 406 using the bigger style flywheel/clutch setup this would not work with the smaller bellhousing. Thus I installed a lakewood bellhousing and also modified it to work. I needed to modify the factory torque arm slightly to bolt up properly. I then need to have a driveshaft made to the length needed. The factory was too long with the adapter plate on the Rockland T56 and the Lakewood bellhousing. I also had a chance to do alot of painting and cleaning during this process and some welding and strengthening was also done to various spots on the cars underside. Well this gives you a idea of what I went through during my 2 week adventure.
To check out pics of my car and to see the specs on the setup check out my site.
http://camaroz28.cardomain.com/id/z28ho
http://community.webshots.com/album/78555624eCxyZe
Old Jun 30, 2003 | 07:35 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Very nice work. Thanks for sharing.
Old Jul 1, 2003 | 01:54 AM
lbrohez's Avatar
From: Decatur,, IL USA Search Posts:NONE.............. Whore Posts: All.................
beautiful.
Old Jul 1, 2003 | 03:38 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That is a sweet car.
Ultimate drivetrain combo and wheel selection.
I'll be going with a 400/T56 on the Formula in a couple of years, I am still working on my 86 LT1 swap.
Old Jul 2, 2003 | 10:39 AM
MdFormula350's Avatar
:hail: awesome job, that is one killer camaro.
Old Jul 5, 2003 | 06:10 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Coo coo, I don't have the 6speed though, and after today at the track, my inability to drive a 6speed its probably a good thing I don't have one.
Old Jul 5, 2003 | 06:22 PM
LilJayV10's Avatar
Engine: 406 Roller
What radiator are you using? I have the universal 31x19 griffith and the thing fits like #$%#@.
Old Jul 5, 2003 | 06:55 PM
Z28HO's Avatar
Car: 1984 Z28 H.O.
Engine: 406cid
I am using a new single core gm aluminum radiator with the plastic cores like you would find stock in a car that came factory with dual electric fans.
Old Aug 16, 2003 | 07:43 PM
1987-396-IROC's Avatar
Car: 1987 IROC-Z
Engine: 4 bolt 383
hey Z28HO
hey Z28HO i was just wondering if that T56 tranny is holding up good cuzz i was planing on doing a 406 biuld up and I dont know what 6 speed tranny to use cuzz im also going to convert it from 4 speed auto to 6 speed manual and i herd the T56 can only hold a bout 500HP or so and i plan on having a little over 500 myself, how much HP/TQ our u running with ur T56 id love to know.
Also does anyone know if u can biuld up a T56 to handle more power if needed?
Thanks,
Old Aug 16, 2003 | 08:08 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
Re: hey Z28HO
I dunno, it handles 800+ hp in the vipers......
Old Aug 16, 2003 | 08:27 PM
LilJayV10's Avatar
Engine: 406 Roller
Re: Re: hey Z28HO
yeah, but has a few upgrades.
Old Aug 20, 2003 | 02:50 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its good to about 500hp as-is.
Old Aug 20, 2003 | 05:05 PM
bes217's Avatar
It is rated to 450 ft lbs. of torque by GM, but has proven itself countless times past this mark
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
