87 IROC w/ zz4
Old Jul 4, 2003 | 01:40 AM
halflife52's Avatar
87 IROC w/ zz4
i saw this car on autotrader.com....the ad says it has the ZZ4 engine. i did some slight research on this engine, and it sounds like a badass engine (355 HP, 405 ft.lbs. of torque). can anyone give me some more info/advice on this car/engine?
oh, and here's a pic of the car:
Old Jul 4, 2003 | 10:06 AM
Metaldrgn's Avatar
Car: Yukon, Tahoe, Expedition, JGC
I dunno, is that a jackstand under that car or is it just me, lol. No the ZZ4 is a great engine. Especailly if you don't want to have to modify it when you get it to raise the HP. I am no engine pioneer though.
Old Jul 4, 2003 | 01:43 PM
halflife52's Avatar
idk, that might be a jackstand or it might be doing a wheelie. who knows. are there any aftermarket products for the zz4?
Old Jul 5, 2003 | 08:29 AM
Metaldrgn's Avatar
I'm just kidding. I can't tell if there is or not. But I do know if you get the right torque converter and the right tires you can do that with an engine that isn't even all that powerfull because of the tremendous power boost you get from takeoff from the torque converter and the engine already at a high RPM while at a stand still.
Old Jul 5, 2003 | 08:59 AM
halflife52's Avatar
i'm gonna call the guy up soon about the car so i can go check it out. then the fun begins....
Old Jul 6, 2003 | 11:33 PM
halflife52's Avatar
bump....anyone else got some info on the ZZ4?
Old Jul 7, 2003 | 07:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.gmgoodwrench.com/perfpart...e/24502609.pdf
Old Jul 7, 2003 | 12:43 PM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
I have a stock ZZ4 in my 67' Camaro. I installed a 88' TPI system with MAF. Have had absolutely NO Problems after 3 years and 20,000 miles. I have TPIS base manifold, 52 mm TB, and level 5 prom, all other pieces are stock. Also have 700R4 trans with 3.36 in the rear. Ran 13.59 at 101 on street tires.
Old Jul 7, 2003 | 01:13 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
You need a hell of a lot more than a converter and tires to do wheel stands unless its a rear engine car.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
italiano67
Sep 22, 2015 08:42 AM
Dragroc
Aug 6, 2001 11:11 PM
89IROCZZ4
Feb 3, 2001 02:17 AM
