What trouble am I looking at?
Old Jul 16, 2003 | 10:03 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I have a 91 V6 with manual trans. Im sick of the problems im getting thrown at me with the current condition of the car. I noticed a 305 or 350 at the junk yard and it looks like it came in a 86 Camaro, not sure if its 305 or 350 however but I will go check it out and post more info then.
Basically my big question is since this motor is carbed is will everything fit? What special items am I going to need from going from a Fuel injected V6 to a carbed 305/350? Will all my accessories and will my radiator be okay? Am i gojng to need more vacuum lines?
Basically what I am scared of is routing
vacuum hoses and such, i realise if i get it I will need a V8 bellhousing and new clutch/flywheel and possibly tranny input shaft.
I have a cherry picker and its no problem to pull and put back in, if there is anything else I need to worry about with the information provided above let me know, I'll have more info on the motor later this week, thanks.
Old Jul 16, 2003 | 10:13 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
do a search
this has been covered literally thousands of times
Old Jul 16, 2003 | 10:17 PM
pasky's Avatar
just tried....tried searching for v6 to v8 carbed, its mostly v8's to v8 carbs or Fuel injected to carbed. Sorry for asking for some help =/.
Old Jul 16, 2003 | 10:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, it is covered often.
You aren't changing an engine, you're transforming a car. They may look a lot alike, but the differences are numerous and deep.
Best way to do this would be to buy an entire donor car (not just the engine), and change over everything that's different. Everything.
The best thing to do is not to do this, but sell the car you've got and buy a factory V8-equiped car. You can learn from my mistake. No charge.
You're welcome.
Old Jul 16, 2003 | 10:47 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
BTW you need the whole transmission not just the input shaft. I tried putting an 8 cyl input into a 6cyl tranny- didn't work and fukt up the tranny (although that has more to do with me opening it up) ;(.
Old Jul 16, 2003 | 10:51 PM
pasky's Avatar
Weird, I thought the V8 T5's came with the same shell as ours, something different on them I don't know about?
Old Jul 17, 2003 | 08:49 AM
five7kid's Avatar
It's like the car - the shells are the same, but the works are different.
Old Jul 17, 2003 | 04:11 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Actually the internals are identical with one exception - gear ratios. The gear on the end of an 8cyl input (for a 2.95 1st) has 22 teeth. the 6cyl input (for a 3.50 1st) has 24. (it might be the other way around I don't rember offhand). The case and internals are the same but the input shaft can't swap - unless you find an 8cly input for a gear set that the 6cyl trans has.
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
