Engine Wiring
Old Jul 24, 2003 | 12:34 PM
bpainter03's Avatar
Engine Wiring
I took the TPI 305 out of my 86 Camaro, and am goin to put a carbureted 350 in it. The only thing i am not sure of is wich wiring needs to stay and wich needs to go. So far i have been told that the ECM can be ripped completely out. I found all the lights so thats not a problem. But, how do i get power to the guages and the dash board? Anything else i am leaving out? let me know
Old Jul 24, 2003 | 03:28 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
the ecm doesnt affect the dash gauges, and lights. Be careful , I would suggest removing the wiring a little at a time...in the end, about all the wires coming from the pass. firewall can go
Old Aug 1, 2003 | 10:08 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Engine Wiring
Just take out the ECM fuse, then turn the key 'on'.... you can even start the car if you want, of course it'll run terrible, and might even stall. But at least with the ECM disconnected from the 12 volt source, you'll be able to 'see' what works.... and what doesn't.
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
