some different 383 questions
Old Jul 28, 2003 | 10:23 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
need help with my 383 swap
ok, I'm getting ready to do my engine swap, but still am undecided on a few things.
1. what to do about the intake, I have TBI, want to do the HSR, but can't afford it right now, so I was thinking about buying a used TPI setup from someplace like thirdgenresource ($500 for wiring and everything), then upgrading up to the HSR, or just going with a good intake and carb setup?
2. need to know what other things i need: fill in list:
383 - $2800
moroso motor mounts - 55
edelbrock headers - 350
dynomax high flow cat - 93
oil pan -
radiator -
dampener -
timing chain cover -
edelbrock high flow water pump - 160
I'm prob forgetting alot of stuff, but any other stuff or input about intake would be greatly appreciated.
Old Jul 28, 2003 | 10:27 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
You will need a flywheel or flexplate, depending on Auto or Stick. Unless your 383 is internally balanced, you will need the externally balanced units. You'll probably have to forget the TBI. To much to sort out. Was your car originally a 2.8 six? If so, tranny will not work. Different bolt pattern and output shaft. And you'll have to round up some V-8 front springs. $400 for headers???? Do some more shopping. You can do better especially on shorties which would work out fine for a torque-monster 383. I would get a high flow waterpump and make sure your radiator is sound.
Old Jul 28, 2003 | 10:38 PM
mgilorma's Avatar
Car: 90 RS
I'm pretty sure it is externally ballanced, but I think I need to get a dampener for it. I have a 700R4 with a B&M shift kit, so that should be good to go. Thinking about getting a new/better stall converter but not sure if I will have enough money for that. I've also been thinking about getting a new radiator, I'll put that on the list. carb or efi?
Old Jul 29, 2003 | 08:26 AM
wesilva's Avatar
Transmission: 200R4
You will need the externally balanced flywheel and balancer. I would go with the EFI if you could afford it. TPI will need mods to feed the larger 383. Check out some of the postings on the TPI board.
Old Jul 29, 2003 | 10:06 AM
mgilorma's Avatar
Car: 90 RS
can I use the flywheel off my 305?
Old Jul 29, 2003 | 03:08 PM
wesilva's Avatar
Transmission: 200R4
The 305 is internally balanced...so no, you have to get one for a 400 small block. In reality, that is the same crankshaft you are using....one from a 400. The mains were either machined down or were cast to the smaller main size to fit a 350 block. Otherwise, they are exactly the same (3.75" stroke).
Old Jul 30, 2003 | 07:39 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
If your car is a V-8 you don't need motor mounts unless you just feel like replaceing them. Unless yours are damaged. All Chevy SBC's use the same mounts.
Old Aug 1, 2003 | 09:46 AM
mgilorma's Avatar
Car: 90 RS
I was just thinking about putting some new ones in while i had it out, maybe some oem replacements or even something better. any ideas?
Old Aug 1, 2003 | 12:27 PM
wesilva's Avatar
Transmission: 200R4
If you can put up with the a little extra vibration, Energy Suspension are nice. They provide extra support and have a safety interlock so if they let go, your motor doesn't tear stuff up.
Old Aug 7, 2003 | 07:08 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
You CAN use the Flywheel from a 305 to a 350. I did it.
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
