wrong vss connector
Old Jul 30, 2003 | 01:15 AM
miller90Iroc's Avatar
wrong vss connector
i am putting a 350 tpi into what was a 1986 v6 5 speed car i am using the 5 speed, and the tpi wiring harness is from a 1985 305 automatic car , the vss conector for the auto is diffrent than the one for the stick,should i cut and rewire or what? the auto is a four pin,and im not sure how it comes out and the stick is a 2 pin ,and it unscrews from the side of the tranny
thanks
Old Jul 30, 2003 | 01:20 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
By your descriptions you it sounds like you are talking about the TCC connector on the auto and the reverse light switch on the manual. Where abouts on the manual is the 2 pin connector, if there is an electronic VSS in the tranny it should be in the tail stock, the reverse light connector is in the gear case, so make sure you are looking at the right parts.
Old Aug 1, 2003 | 03:10 AM
HybridZ28's Avatar
The 1985 TPI harrness doesn't have a VSS connector since the spedo was cable driven in '85.
What year is the motor/tranny from ?
Old Aug 3, 2003 | 04:05 AM
ok, so all i have to do is wire the backup lights, which i am guessing is two of the three wires on the auto, thanks for the help the wiring harrenes is an85 the t5 is an 86
Old Aug 3, 2003 | 08:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Just change the VSS out, put the right one into the trans that you're putting into the car.
Attached Thumbnails wrong vss connector-t-5-speedo-gear
Old Aug 3, 2003 | 10:40 AM
The_Raven's Avatar
RB, can you provide some more info on thsoe sensors?
I have an '85 Jimmy, that just has a cable drive for the speedo, and the ECM that I am using doesn't like the optical VSS that I am using, it was worth a try. I need to swap to a magnetic VSS of some sort
miller: I'm not 100% sure on this but I beleive the reverse light wires are in the car, more specifically attached to the nuetral park switch that should be attached to the shifter in the console. If you don't see that switch on the tranny, there should be about 6 wires attached to it, take the console cover off and look there, the reverse light wires will green and blue. The wires in the 4 pin plug attached to the auto tranny should just be the TCC and 4th gear wires.
GTAman
Jul 3, 2024 07:29 PM
gta892000
Aug 11, 2019 11:16 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
