C5 engine for my 84 Z28
Old Aug 6, 2003 | 03:36 PM
viperfan's Avatar
OK im looking for any info or web sites on how to put a C5 engine into my 84 camaro Z28, i would like to find a web site if there is one that shows every thing i need to do this and how to do it, one that has pics and all those kind of things.
thanks alot,
Old Aug 6, 2003 | 08:53 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
If you do not already have the engine yet, I would highly recommend that you get you're LS1 engine from an F-Body, and not a C5 corvette....
The cost factor alone will save you major headaches, and it will also provide enough for you to make a good deal of modifications to the Camaro/Firebird LS1 engine.
Do you have the engine yet?
Old Aug 7, 2003 | 01:20 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Ok, viperfan, i suggest you do some research before you get in way over your head.
The engine you are looking to swap is called the LS1. It is an aluminum block aluminum headed 346 cubic inch generation III small block. It is completly different than any other small block prior to '97. Problem is due to the different oil pan, the motor straight from the C5 will not fit in your '84 Z. GM put the same exact LS1 in the 98-02 Z28's and SS's, as well as firebird formulas, and trans ams. that is the motor you are looking for, it has the right oil pan to fit in your '84. It is virtualy the same motor. There is a full thread at the top of the page on how to swap a LS1 into a thirdgen. I suggest that you start reading there to find more information.
There is more info on the LS1 and LS1 swaps on this board than you can think of, so before asking questions use the SEARCH feature at the top of the page. It will save you a lot of headaches asking questions that won't get answered, because this questions comes up almost everyday.
Old Aug 9, 2003 | 04:54 PM
Parrydise7's Avatar
Look at the stickies at the very top of this board. There is all kinds of info available there.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
