LT1 in a 86 IROC speedo question
Old Aug 8, 2003 | 04:11 AM
FOO Z racing's Avatar
Car: 86 IROC-Z
Engine: LT1....not running
I put the motor and the 6-speed in. My speedo is cable driven and the T-56 is electronic. What do I do to get it to work. Should I get a gauge cluster that is electronic from like a 90-92 or something. How would this work with wiring?
Thanks, FOO!
Old Aug 8, 2003 | 11:15 AM
mat89RS's Avatar
remove the VSS sensor from the transmission, install your old speedo cable/gear.
Old Aug 8, 2003 | 02:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If only it was that simple....
JTR (Jags That Run) used to sell an adapter kit for hooking a cable drive up to a T-56, but they quit. It was about $300 IIRC. That might have something to do with it, maybe slow sales due to the $price$ kind of held the volume down too low.
Old Aug 10, 2003 | 05:21 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I saw something in the Pace Parts catalog that was called a "cable x". It converts a speed sensor to cable somehow. There was a discussion on this a while ago. I think it was made by abbott something or other. A search will probabaly help you more.
Old Aug 11, 2003 | 08:37 AM
mat89RS's Avatar
ok I think the 93 was a question of removing the sensor and that was it, maybe it's different for newer T56
Old Aug 11, 2003 | 03:46 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I know on a 94 speed sensor there is no actual gear. It looks like an ABS wheel sensor. I am pretty sure it is some sort of magnetic signal.
Old Aug 12, 2003 | 12:20 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You will be better off converting to the newer dash cluster.
midge54
Dec 27, 2019 04:14 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
mustangman65_79
Aug 11, 2015 03:17 PM
