LT1 T-56 can i use 4th gen clutch assembly
I was going to buy an LT1 with a T-56 for $2500. So I was wondering if I could go ahead and pull the clutch and brake assembly out of the same car and throw it in my third gen. If I can then it will be much easier to work with I think then trying to peice the clutch assembly together. Any help on this would be good.
James
James
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Use the 4th gen master/slave cylinders along with the 4th gen clutch and flywheel assembly. Include the pedals too if you have a 700R4 to replace. That's what I've read anyway...
Car: 1987 Trans Am
Engine: Lt1
If your car is already a 5 speed, then that setup will work. The 4th gen setup will bolt in also. If I remember correctly, it's something like 3 bolts. Either way, it is easy to hook up and no peicing together should be necessary.
My car is not a manual its an auto already. I can get most of the parts I need from the donar car and if the tech article is right I should just have to cut the hole out that should already have an outline in the floorboard right? I know you have to mount the master cylinder on the firewall but if the motor is out already then it should be easy to get it in there correct.
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The 4th gen pedals will fit, but they have the gas pedal assembly made to them. Most people cut it off; I don't know if you can use it with the gas pedal still attached.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
rsrmoore
Aug 7, 2015 08:44 PM
