Stand alone harness from Speartech. Mass air or Speed Density?
Which 1 would be the best to get? On a mustang, I know the Mass air would be the 1 to have. Is it the same for the LT1's?
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Same for the LT1. You need to have MAF for optimum performance. John, is a smart guy. He can probably customize one for speed density if you really want to go that route.
I had already talked to him before I posted this and he said he could make it speed density if i wanted to go that route. Didn't know if that was the more popular swap or not. I will have a 96 harness so I guess thats mass air but I'm not sure.
Brian
Brian
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you plan on tuning your car yourself, go with Speed Density, otherwise go with MAF. MAF takes to mods better.
I am running speed density on my setup since I will be tuning my car and don't care for the MAFs.
Oh, and I have this cool air intake that I am going to run
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I have the Maf harness from speartech.. can't say enough good things about those guys.. quality product..
my opinion Maf.. you can see my ls6 one tucked behind the filter..
Car: 1990 Firebird Formula
Zepher man your motor is looking sweet...
I would go with MAF... I have a 93 Speed Density motor and I am in the process of looking for a 94 up harness and an 8051 pcm so I can reprogram the stuff myself. (without burning chips)
You can actually switch to speed density mode with the MAF harness and not plug in your mass air flow sensor. (custom programming)
IMHO the speed density harness and pcm are not worth it because you would need to burn chips... unless you already have that setup I would go with the more easily programmed setup.
I would guess you would need $200-300 to burn your own chips with the Speed Density ECM, as opposed to $95 for the cable from AKM that will allow you to plug in and upload new programming to your PCM. Tunercat is like $80 with the bin you'll need, between the cable and tunercat you would be able to do whatever you needed for custom programming.
I am going to use TunerCat to program my setup. Julian has LT1 Edit for his setup.
Here is part of the Switch Table
Here is a larger shot showing some other items
http://www.transamws6.com/pics/cats.jpg
eightsixseven
Dec 16, 2024 01:50 PM
