Swapping 305 to a 454 is it possible?
Old Aug 20, 2003 | 08:27 PM
chrisg85TA's Avatar
ok im a newbie here, i own a 1985 Trans Am i think it is a gta, i have the 305 4bbl.
with an automatic tranny.
I was wondering if it is possible to get rid of the 305 and put in a 454 with a manual transmission, if so what will i need to replace, and what type of improvement should i expect your feedback will be apreciated.
Old Aug 20, 2003 | 09:04 PM
dennis6's Avatar
Car: 1991 Camaro RS
Yes you can do this. It would be easier with a TH400. This is an expensive and difficult swap. Do a search its been done before.
Old Aug 21, 2003 | 03:20 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't think it can be done with a typical big block 4 speed tranny because there is no torque arm mount.
But yes, the 454 will drop in.
Old Aug 21, 2003 | 01:52 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
It can be done with any tranny that will bolt to the block. What you need is a diffrent torque arm and www.jegs.com is the only place that has the correct one that I know of. The Jegs arm mounts to the floorpan of the car, not the tranny. Also easiest way to hook up the clutch on a older 4 speed(like a saginaw or muncie) would be to get a hydralic throw out bearing and get the pedals and clutch master cylinder off a stick 3rd gen.
Old Aug 21, 2003 | 04:18 PM
chrisg85TA's Avatar
thanks for you feedback guys
Old Aug 21, 2003 | 05:23 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
All the BBC swap info is on my page at www.koolmeister.com
Miles
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
st.evel07
Aug 13, 2015 06:15 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
