will this work
Old Sep 13, 2003 | 08:33 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
will this work
i just bought a 83 z28 and i bought it for the engine it has a 4bbl 305. i have a 92 firebird with a 305 tbi. will the 83 305 work in my car if i put in intake manifold and tbi on. and does anyone know the hp ratings on a 83 305 z28 engine thanks. i looked it up and it said 190 but thats with a carb what would it be with tbi?
Old Sep 13, 2003 | 11:28 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think they changed the intake bolt pattern in 87/88, might have to swap heads also w/that. Have you done a compression check on teh "new" motor yet? Just making sure it's good before you start out on it.
Is the 92 engine that bad?
Old Sep 13, 2003 | 11:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If the engine you have is the 5.0L HO, which is the 190hp engine, leave it as is and forget the TBI... the HO is a MUCH better engine if its got its 4bbl, and very rare in an '83 Camaro.
Old Sep 14, 2003 | 11:48 AM
Car: 1992 Firebird
well i would leave it carb but i live in california and we have stricked emissons. i think its nothing after 88 can be carbed and still pass.i think.
Old Sep 14, 2003 | 12:06 PM
Engine: 5.7 / 7.4
I've heard they also pop the hood & check that shiz too
which is why KED85 made his 2.8-3.4 swap look exactly like the 2.8.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
