TPI on a 383?!
Old Sep 21, 2003 | 05:53 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
TPI on a 383?!
im swapping my 305 tpi for a 383, was going to go carb but was wondering if the 305 tpi setup will work on a 383. anyone know? thanks
Old Sep 21, 2003 | 06:04 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
Yes it will fit on there but you would have to keep all the computer crap and have it retuned...Carbed will give you more power but you may give up convenience in the long run...equal trade offs eather way!
Old Sep 23, 2003 | 10:13 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
You can use the old TPI setup from your 305 but you will need bigger injectors and replace the fuel pump. Sensors will need to be replaced as well such as the knock sensor and so on. Myself, I am looking to buy a 383 (warranty issue) vice build one. Best place to find a 383 would be Ebay.
Old Sep 24, 2003 | 02:55 AM
cdartz's Avatar
A stock TPI is going to choke your 383. Put a Stealth Ram on it.
Old Sep 25, 2003 | 08:28 PM
Kontrax's Avatar
Car: 86 Camaro
thats what i figured. its a gta and i just wanted to swap the intake on to the 383 just to make it easier so i don't have to chase wires. wanted to do a 6 pack on it but after swapping a motor in my camaro and seeing what i have for space with the stainless lines, i figured id take the lazy route and just put the tpi back on.
toronto formula
Nov 10, 2015 06:17 AM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
