1971 350 block
Old Oct 3, 2003 | 11:49 AM
Ardels91TA's Avatar
1971 350 block
I just bought a 350 block from 1971, don't know if its a car or truck. ANyway, just want to make sure that there are no major differences between old 350 blocks and newer 350 blocks. I know the dipstick tube isnn't in the same place. Anything else. It has a 383 stroker setup in it, and I want to either use the super-ram, or stealth ram and put it in my 91TA. ANy suggestions, and info on problems I may have would be great. THanks
Old Oct 3, 2003 | 12:55 PM
cdartz's Avatar
I would suggest you take it to a reputable machine shop and have them verify that's it's a 383 stroker motor, and check all clearances for you to verify condition.
Old Oct 3, 2003 | 01:35 PM
Ardels91TA's Avatar
I know its a 383, becasue my brother helped the guy build it a last year in school. I just want to make sure that a 1971 block will match up to my 91 4L60E, and so on. I'm almost 100% sure it does, but just wanted to see what you guys thought. Also want to make sure new heads will fit it. Vortec, fastburn, etc.
Old Oct 3, 2003 | 02:36 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You have to get a new flywhell or flexplkate to mate the 2 piece rear main seal to a single seal tranny.
Old Oct 4, 2003 | 01:23 AM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
didnt the 4L60E come in the 4th gens ?
Old Oct 5, 2003 | 10:09 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Wow. No one know a damn thing here.
THat might be a little extreme but there is alot of BS floating around.
1st off you do not have a 4L60E - you have a 4L60 more commonly known as a 700R-4.
2nd you do need a new flexplate but not for the transmission. Your current motor has a 1pc RMS (on the crank). THe 71 block has a 2pc RMS. The Flexplates are not interchangeable between the 2 diffrent designs. Use whatever Flexplate the motor had before.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
BBSDesigns
Aug 11, 2015 07:39 PM
