parts from 305 to 350
Old Sep 28, 2003 | 07:17 PM
demonchild's Avatar
what internal engine parts are intercahngable from a 305 to a 350? can i reuse the crank and rods?
Old Sep 28, 2003 | 08:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The cranks are the same castings, opinions vary as to whether they're balanced the same (haven't see convincing evidence, personally).
305 rods are supposed to be lighter, and therefore weaker. But, I wouldn't swear to that one, either.
Cam, lifters, pushrods, timing set will fit either (assuming same type of cam, anyway - roller vs. flat tappet). Oil pumps are the same. Those things I know for sure.
Old Sep 28, 2003 | 08:46 PM
Irocster's Avatar
Car: 1989 IROC-Z
Transmission: 700R-4
Just go with a 350.
Old Oct 4, 2003 | 05:06 PM
swise67's Avatar
same except for bore
same setup except for bore 305's are good for wiping cam lobes off for some reason ?
Old Oct 5, 2003 | 09:24 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
The crank and rods will exchange just get everything balanced.
Old Oct 6, 2003 | 12:02 AM
demonchild's Avatar
you guys say that the 305 part are weaker. how much weaker. i want to run a pretty aggressive cam and make like 350 hp at the crank. will the rotating assemble hold up?
Old Oct 6, 2003 | 01:04 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
I personally wouldn't worry about it with 350 HP. And the argument is still out about 305 parts being weaker.
Old Oct 6, 2003 | 02:32 PM
swise67's Avatar
camshft
running a .680-..680 lift with 1.5's and 1.6's on a crank out of a 305 { same 3.48 as a 350sbc ) like said above make sure to get it all balanced mine is balanced to 8500 rpm I paid a little extra for good rods and such :lala:
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
