Avoiding disater
Old Oct 16, 2003 | 08:46 AM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
Avoiding disater
OK I need everyones help and advice. i am building a new motor for my 85 IROC, heres what i have so far.
4 bolt main roller block fully machined.
Scat 9000 Crank (383 crank)
Scat Rods
Keith Black Hyper. pistons
AFR 190 heads
3.42 rear gears
700r4 Auto (freash rebuild)
10.1:1 compression
1st question is, how do you all think this cam would work: Its a Crane roller cam custom grind #11HR00028 duration @.50 is 222/230 lift .518/.539 (with 1.5 rockers)? I am told that this would be good for 2500-6000 rpm.
2nd question, my intake plans are to use SLP runners, port my base the best I can, and add a 52mm TB. I am wanting to keep this looking close to stock, but still put out some respectable power.
3rd question, I am thinking about updating the computer to a 87 or newer and work on burning a chip for this set up. Any thoughts?
I know some of this might seem a little odvious but I don't want to make any costly mistakes, money is tight.
Thanks for any help!
Old Oct 16, 2003 | 04:26 PM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
Anybody ???
Old Oct 16, 2003 | 07:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Patience, my son. Some of us are gainfully employed and need to ensure our boss is not looking as we contemplate your dilema...
I think you're trying for too much cam. I don't know what RPM SLP says their runners are good for, but 6000 may be stretching it a bit. I have a bud who uses their runners on a ZZ9-cammed ZZ4 (much, much porting work) that he shifts at 6000, but I think he's over-shifting. He'd probably be faster if he shifted lower.
I'd guess a 58mm TB is in order as well. While you're doing the TPI upgrading, might as well go for SD, since you're planning on PROM tuning anyway.
Also, cam/rod clearance is an issue with strokers. Make sure they like each other.
I hope a nice loose converter is part of the TH700 freshening plans.
Old Oct 17, 2003 | 08:52 AM
My85IROC's Avatar
Car: 1985 IROC
Transmission: A4
Thanks for the reply, wasn't thinking about work so much yesterday, kind of a day off at the office for me.
My biggest concern is the cam, I don't plan on running this motor to 6000, I think shifting at 5000 to 5500 is more reasonable for TPI. Basicly I don't want to over cam, or under cam.
Swiching to SD is just scary, I haven't done any prom tuning ever so I worry that it will take months to get a chip that is even close to good. Is there any one that has Bin files (if that's what they are called) that I can start with so I am close to what I need?
I do plan on a converter that has a stall speed of 2500, which I am thinking matches the cam I have been looking at.
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
2012sergen11
Oct 13, 2015 07:38 PM
project89
Sep 22, 2015 09:35 PM
E_S
Aug 29, 2015 04:09 AM
blue86iroc
Aug 13, 2003 03:09 AM
