took engine out, a few questions.
Old Oct 19, 2003 | 09:30 AM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
OK i have a 86 z28 i took the engine out getting ready to put the 355 in a few questions tho, what do i do with all the old wires that dont hook up to the new engine? do i cut them and seal the ends? also can you take out the ecm or would that requiere rewiring, And what are the sending untits on the cylinder heads,what are those for also i took the distributor out and theres a chunk out of it i was planning on getting a petronix hei kit but now i need a distributor any suggestions hei or points all help is apreciated!
Old Oct 19, 2003 | 02:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
IF you plan on dumping the computer setup then yea, you could remove almost all the wires and vacuum lines assosiated with the engine. The sensors on the heads are coolant temp, drivers side is for your dash guage the passenger side is for your electric fan.
Old Oct 20, 2003 | 09:02 PM
anymethod's Avatar
Car: 1986 Trans Am
Engine: carb 305 LG4
Transmission: TH700-R4
How is a chunk of your distributor missing?
~Matt
Old Oct 21, 2003 | 03:11 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I would try to preserve the harness in case you want to drop in something high tech in the future.
Old Oct 26, 2003 | 03:02 PM
Car: 85Z28
I dont know how theres a chunk out of the distributor there just is
Old Oct 27, 2003 | 12:11 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
IF you are going to a non computer controlled setup just unplug the ECM and accoiated wiering harness and stach it somewhere incase you ever need to return the car to stock.
84z96L31vortec
Aug 20, 2017 12:16 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
squiggy2
Aug 9, 2015 09:30 PM
