LO3 toL98 shortblock swap, flexplate ?
Old Oct 22, 2003 | 07:03 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I did some searches on flex plates and am now confused. Can I re-use my L03 flexplate and harmonic balancer on a L98 motor. I have heard it both ways. Oil pan and the timing cover the same ?
Old Oct 23, 2003 | 03:48 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Yep, should be the same. The flexplate/balancer are internal balance on both motors. I'm not quite sure about the pan, but it should be the same. Timing cover is definitely the same, except for possible the timing mark, but that can be solved with some timing tape or a new timing pointer from Summit.
Old Oct 23, 2003 | 05:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The shortblocks are identical. Flexplates are identical. Tin is identical.
You should be in good shape.
Old Oct 23, 2003 | 06:27 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
thankyou
Old Oct 24, 2003 | 01:44 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Actually, 1 pc rear main seal cranks are externally balanced from the flywheel/flexplate.
Old Oct 24, 2003 | 03:09 AM
kfoley's Avatar
Car: '85 Z28
Oh, I didn't know that, thanks for the correction...
84z96L31vortec
Aug 20, 2017 12:16 AM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
