Crossfire electric pump, into TPI/Carb conversion...
Old Oct 27, 2003 | 09:05 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Does anyone know if an 83 Crossfire intank fuel pump will hook up to an 86 fuel sending unit?
I'm considering swapping from TPI to Carb, and am already aware of the Mallory #4309 after reading about many swaps that took place on these boards.
The folks over at Jegs recommended to run a 3/8's line over the stock 5/16's return line from the AFPR to the tank, to avoid leakage (this if I maintain the stock TPI electric pump).
Although it's a good idea, I'd much rather keep the stock fuel lines functional. I read on these boards that a stock Crossfire electric pump only puts out about 15-25 psi (over the TPI's 50-60 psi), and was curious to see if anyone every adapted one to their TPI's fuel sending unit. This should eliminate too much pressure, plus keep the Carb happy (through the AFPR of course).
I have access to my tank via a trap door, so the install will be relatively easy. Has anyone here ever done this?
ANY feedback would be appreciated.
Old Jul 15, 2009 | 04:26 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Crossfire electric pump, into TPI/Carb conversion...
any updates on your progress?
Old Jul 15, 2009 | 04:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hmmm, the OP hasn't posted anywhere on TGO since 2004. . .
But, can we assume you found this with the function?
If so, for that.
But, in general,
Old Jul 15, 2009 | 04:49 PM
KITT1983's Avatar
If so, for that.
But, in general,
I found this post using the search feature but if I can get any help on this matter. I dont care how old the post
Old Jul 15, 2009 | 05:10 PM
Twin_Turbo's Avatar
dimensionally the TBI and TPI pumps are the same, all you may need to do is swap connectors/do some wiring. Regulator regulates pressure, pump merely creates flow. TPI pump has a much higher flow capacity than TBI pump and as such a higher dead head pressure rating.
Old Jul 15, 2009 | 05:24 PM
five7kid's Avatar
Originally Posted by KITT1983
...if I can get any help on this matter. I dont care how old the post
Being almost 5 years old, with no sign of the OP in the last 4, makes that very unlikely.
Old Jul 15, 2009 | 05:34 PM
KITT1983's Avatar
but will a crossfire fuel pump work with a TPI or TBI sending unit? do you have any links for this mod for a TPI fuel pump/ TPI sending unit swap
thanks for replying
Old Jul 15, 2009 | 05:42 PM
Twin_Turbo's Avatar
Yes, the sending unit/ level float can hold either pump as they are dimensionally the same. I don't have a good pic but here's one of a fuel sending unit:
See the pump at the end? it's held in by a clamp and a rubber hose to the hard line. If you buy a TPI pump it will just go in that same place, mounted the same way.
Here are identical pumps, they are off vettes but the one is a TBI and the other a TPI pump
The black rubber sock around the pump is just there to reduce the pump noise.
Old Jul 15, 2009 | 06:02 PM
KITT1983's Avatar
thanks for the help dude
Old Jul 19, 2009 | 10:07 AM
KITT1983's Avatar
is that TBI in the photo a crossfire pump and sending unit?
RazorN8
Jan 7, 2022 11:44 AM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 6, 2015 09:03 AM
