305 -> 350 can i still use the q-jet?
Old Oct 30, 2003 | 09:50 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
Would it be ok to use the stock CC q-jet that came on my 86 Z28 305 and put it ontop of my new 350? what adjustments would need to be made and such? thanks in advance!!
Old Oct 30, 2003 | 10:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No problem.
Adjust the idle, IAB, perhaps the choke. DR rods & B hanger, if you haven't done any secondary tuning yet, is a great combo.
Old Oct 31, 2003 | 03:15 PM
Car: '86 IROC
sorry im a little new when it comes to these q-jets, could you please explain? and would you suggest staying with this or going non-CC carb? thanks!!!
Old Nov 1, 2003 | 03:19 PM
five7kid's Avatar
The secondary fuel metering is accomplished via tapered rods. They are pulled out of the fixed secondary jets based upon the opening of the air valves, which are spring-loaded to only open up enough to meet engine demand (even though the throttle plates below are opened mechanically).
The fuel metering is taylored by the size and taper of these rods, and by the amount they are held out of the jets by the hanger. For the majority of applications, a set of DR rods and a "B" lettered hanger will work very well.
The CC carb will give you the best combination of economy and power.
Old Nov 1, 2003 | 11:37 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
rods
i got some rods from edelbrock they are sixe ck but i have a 305 i have installed them yet, are these a good size or am i off, or does it matter, or is the dr rods better for a 350?
i have a b size hanger as well... cant wait to get my carb rebuilt and running right
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
