planning to tune up my engine
Old Nov 1, 2003 | 09:04 PM
firebirdtank's Avatar
Car: 1985 firebird
Engine: V-8 305
Transmission: TH 700-R4
i have an 85 firebird 305, carb automatic...i was planning on fixing everything up on it, but i wasn't sure what to get...so i figured i'd ask the people who have had some experience with this...i wanted to replace the carb, intake manifold, cam, lifters, rockers, pushrods etc...i would like some suggestions on what would perform best, without having to rob a bank
Old Nov 2, 2003 | 11:43 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
if you are capable i would do bearings too in the lower end.....lol....i did the whole top end once and let the bottom cuz i wasnt ready to tackle it...only got about 300 miles outta her before i spun a main bearing
Old Nov 5, 2003 | 01:38 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Ya, while you're in there you might as well throw new bearings and rings in it. It only costs a few bucks and takes a couple hours (unless you're me and you find other things to do to it).
Here's what I would reccomend:
Holley 650cfm vacumn secondary carb
Edelbrock Perfomer RPM intake manifold
Comp Cams Magnum 1.52 rockers
Comp Cams Magnum pushrods
As for the cam I need to know what kind of drving you do, what rpm range you want for the motor, what kind of tranny, what stall speed, and what rearend gears you have. Then I can make a good reccomendation.
Old Nov 5, 2003 | 07:18 PM
Car: 1985 firebird
Engine: V-8 305
ok...basically everyday driving, i have a th 700-r4, umm im not really sure about the rpm range...honestly i've just started working with cars over the past few moneths...i start school for it in a few weeks...but i want to learn outside of school...so...any recommendations?
Old Nov 5, 2003 | 10:32 PM
kfoley's Avatar
Car: '85 Z28
I'd look at Comp Cams XE256, or if you want to go the cheap route, a Summit K1102 cam which is 204/214 dur. Both those cams will be good for daily driving and will make plenty of low end tq.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
