S-10 2.8 into 84 camaro
Old Nov 4, 2003 | 04:59 PM
88dragulaSC's Avatar
Car: 2 camaros, 1Ta, 1firebird
Engine: All 350 but 1 2.8
Hey everyone, I recently swapped in a 2.8 form an 83 S-10 truck into a 84 camaro. Everything bolted up ok and the engine started up like any other swap that I had done. But when I push the clutch in, the pedal has almost no resistance. It won't go into any gear either. I thought that the slave cylinder was bad so I ordered a new one and it still didn't have any effect. I was wondering what would I need to do to make it work.Put the truck tranny in? I am getting really frustrated and any help would be great.
Old Nov 4, 2003 | 10:09 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Try posting this in the V6 forum, more V6 specific knowledgable peeps there. Also try a search in teh tranny forum, might even find your answer there.
Welcome to the boards!!!
Old Nov 4, 2003 | 10:18 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
Try bleeding the clutch slave cylinder.
Old Nov 4, 2003 | 11:03 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Could be the master too. A bad master will cause the clutch petal to have no resistance.
Old Nov 18, 2003 | 03:29 PM
Bad master eh? OK I'll try to replace that too and see if it helps. Thanks
Old Jan 29, 2004 | 09:37 AM
I found out that the slave and master cyl. were fine, but the pivot bolt was so worn that it was letting too much of the slave cyl. to travel. It is up and running now. Time to get started on the 87 T/A
Cleotiz
Jan 6, 2018 08:56 PM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
