a few engine swap questions
Old Nov 16, 2003 | 09:51 PM
Paul_Ishmyknob's Avatar
Car: 1985 Trans Am
Engine: 305(LG4)
getting ready to swap my 305 out for the 350 i have, and was just wondering if i could cut a few corners such as running the stock HEI, or will i have to go ahead and spring for the aftermarket HEI setup?
also, how much horsepower/torque can the T5 withstand? what can i do to strengthen it, if anything.
Thanks,
-Curt
Old Nov 16, 2003 | 11:02 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I swapped a 350 and I used the the same HEI distributor that I had on my 86 Z28 LG4 motor. Worked fine and later updated it with Hypertect cap and rotor.
Old Nov 17, 2003 | 07:43 AM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Did you still retain the ECM when you swapped to the 350 from the LG4, and if not, how were you able to retard the timing while RPM increase?
Old Nov 17, 2003 | 09:41 AM
86z/92rs's Avatar
Yes I retained the ecm. The shop that installed the 350 motor did everything since at the time (many moon ago) I was not mechanically inclined to do any motor work. The timing was advanced 2-4 degrees.
Old Nov 17, 2003 | 02:00 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
T5 Upgrades
As far as your T5 goes, Hanlon Motorsports has excellent upgrades for the World Class T5. I went with the high end rebuild, steel retainer and a billet shifter with great results.
http://www.hanlonmotorsports.com/
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
