Bottom Line $ on eng swap
Old Nov 19, 2003 | 12:36 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
I had a 85' IROC 305 TPI and I loved the sound of the motor in that car.
I have a 84' Sport Coupe 2.8 V6
How much $ would it cost to have a 305 TPI put in my car? (I live in Phx, AZ)
Old Nov 19, 2003 | 04:18 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Then engine itself should be cheap since guys often dump them for 350s. Without any details your biggest expense will be uprgading stuff to make the 305 work. I would WAG it around 700-1000 labor.
Old Nov 19, 2003 | 07:15 PM
cdartz's Avatar
I've been through the swap you want to do, and honestly it's not worth it unless your Sport Coupe is spotless. If it's showing it's age then you are better off selling it and buying a 305 car.
Old Nov 19, 2003 | 07:48 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
forget the 305 and just go 350. you'll like it a lot better. plus i think the 305 isnt worth the time or money when you can pick up a 350 for a few bucks more.
Old Nov 20, 2003 | 12:02 AM
pskel350's Avatar
your best bet, would be to get a donor car, because you are gonna need a lot other then the engine. a 350 would be nicer
the swap isnt really that hard, everything will pretty much just "bolt in". i would think labor should be no more then a grand.
good luck with it
Old Nov 20, 2003 | 02:08 AM
azcamaro's Avatar
My car is in really good condition. I've been doing alot of mods\upgrades to it.
I think I'll take the advice and go 350. I remember my IROC got really good gas mileage (I drive 34 ml to wk & back).
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
armybyrd
Aug 10, 2015 09:23 PM
