what do i need to change on my rs plzz help
Car: 1989 RS Camaro
Engine: V6 2.8 liter
Transmission: manual
ok, now i need some more help, if u could tell me i need to kno what i need to change to go from a 173 to a 305 and also i would like to kno if a a 305 would be good or should i just go for the 350 SBC
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any small block swap is better if you go bigger. 305's are a waste of time when the amount you spend on it can be equally matched with a 350. Your money will go a lot farther in the 350. The only reason to go with a 305 is if you scored a free one that is all ready to go.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I'm with Shifty....I'll go one step farther and say if you don't have a 305 in the car, go with the 350. The hurdles your going to have to work out are the same for both SB. Might as well go 350.
