87 305 TPI wires cut what are they??
Old Dec 3, 2003 | 10:52 PM
TPIMarow6.6's Avatar
Car: 85 Camaro Z-28
Engine: 6.6
Transmission: 5-speed
Ok iv got a complete wiring harness there are some wires that are cut, i know most of them are grounds that go to the back of the block but here goes, if you have an 87 wiring harness for TPI sitting on your ground uncut it would be much easier to help me.....There is a Brown wire that is cut that comes out of the same spot of the wiring whip as the oil sender and the sensor that is on the coil bracket and all the driver side injector plugs come out of the same spot and the distributor plug as well. the other wires com out of the same place as the pass. side injector plugs, upper plenum plug(MAT sensor?), and EGR plug with 1 other misc. plug that i realized goes to like nothing. any ideas? there is a peachish wire that is cut and the other ones are black which im told are just grounds to the back of the heads....help will be greatly appreciated, also if anyone has the wiring harness off of the computer whip that goes in side the car to the fuse box, the big whip has the ALDL plug on it and then wires go past that to the fuse box, there is a green wire and a black wire that i cant figure out. any help? (the car i bought the parts off of had A/C if that has anything to do with it) thanks!
Old Dec 4, 2003 | 06:19 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Your best bet would be to post pictures. Is the air pump still hooked up?
Old Dec 4, 2003 | 08:54 PM
Car: 85 Camaro Z-28
Engine: 6.6
well im doing a TPI swap on my car, so all i have mainly is the harness computer TPI parts and other sensors and all required crap. but all i need to know i what those wire go to, there are also some black ground wires that were cut that go to the back of the motor somwhere or down by the tranny, i can post apic of the harness on the floor of my garage. if that helps you guys help me
Old Dec 4, 2003 | 11:27 PM
wm_sorg's Avatar
Is the engine at a point where you can connect the harness to it. That would be a good place to get started. I have some pictures of my old TPI setup lying around I can post that you might be able to compate to.
Old Dec 5, 2003 | 02:45 PM
Car: 85 Camaro Z-28
Engine: 6.6
that would be cool if you could put up pics of the old TPI setup, most of the wires are back by the distributor.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
