will this fit in a third gen
Old Dec 6, 2003 | 09:39 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I wont this set up in my car
http://www.whipplesuperchargers.com/...sp?ProdID=1169
will it fit?
has anyone done this
whipplecharged vortec 4200
Old Dec 7, 2003 | 05:54 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
no
Old Dec 7, 2003 | 06:31 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i disagree, it would fit, it wouldn't be a bolt in type item though, and i'd expect to pay 4 or 5 digits for the swap
Old Dec 7, 2003 | 12:16 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Ehh, I didnt find a version for the SBC... but the
whipplesupercharger looks pretty similar to the
eatons/roots type supercharger ..
Old Dec 7, 2003 | 03:25 PM
Engine: V8
oh, just the supercharger? yea they make whipple intakes for SBC, whipples are a very efficient supercharger too, one of the best
Old Dec 7, 2003 | 05:52 PM
define fit
lol
Old Dec 7, 2003 | 09:13 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
With money, time, know how and patence anything will fit in anything. If I wanted to I could make a 800lb man in a squirel cage power my car. Will he suffer a heart attack with in a mile? Yes, but will he power the car, yes. Anyways it would be cheaper and a hella alot easier to stick a ATI or Vortech super charger under the hood or have a roots poking out on a sbc. But theres no fun in playing follow the leader either. If you have the $$$ a twin screw set up on a big block would be killer.
Old Dec 7, 2003 | 09:19 PM
agreed, but in this case
this is a newbie asking this question, and just because he has to ask, in case, the best answer would be
no it will not fit
Old Dec 7, 2003 | 10:22 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yes, it could be made to fit, and Whipple is the best Supoercharger out there, but also costs a sheesh load of $$$$$$$$$$$$$, which a procharger or vortech can be had for less. But it's your call.
Old Dec 7, 2003 | 11:24 PM
kairles's Avatar
Engine: 383/LGX
I know money buys performance, style, etc. I just was not sure if the 4200(inline six) would fit because I don't know the lenth of the motor I don't wont to cut anything
Old Dec 8, 2003 | 06:24 AM
see my original post
lol
Old Dec 8, 2003 | 10:07 AM
Engine: V8
yep, due to the oil pan and the inherent height of inline engines, and the mounts it uses, i assure you that cutting would be the easiest of the modifications, you would almost HAVE to figure out some way to modify the front frame (k-member) to clear the pan and everything else or cut into the floor and put a hell of a kink in the....nm...i don't wanna think about it...it'd just be entirely too much hassle
Old Dec 8, 2003 | 01:07 PM
Engine: 5.7 / 7.4
maybe h needs to take a look at some dodge or volvo slant sixes & see their layout.
Old Dec 8, 2003 | 04:38 PM
did you ever see the 4wd version?
the front axle runs THROUGH the oil pan
Old Dec 9, 2003 | 10:08 AM
Engine: V8
*shudders*
Old Dec 9, 2003 | 12:08 PM
Guest
Guest
Posts: n/a
I think we had pretty much determined before that this engine isnt going to fit with any simplicity. I've seen it on a stand, it doesnt look promising at all. Its basically the same length +/- but the problem is the height, its alot taller at the front edge. Probably with a different crossmember and a cowl hood, it'd work, but I dont think the work is worth the effort when you can build up any number of other combos available that arent such a hassle and get similar results.
Old Dec 9, 2003 | 01:45 PM
windowlicker's Avatar
All I have to say is: WHY?
why would you want to try and retrofit a supercharger from an inline-six motor?
You don't mean you want the whole setup in your car, do you? The motor and supercharger?
Old Dec 10, 2003 | 03:32 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Basic answer (i.e. bolt-on), no.
With fabrication, I'm sure you could, however even if you got it on there it wouldn't produce much boost on a 350 when it's designed for a 4.2L motor. It just wouldn't put out enough volume.
Old Dec 10, 2003 | 03:58 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
With fabrication.. anything is possible... that's a pretty gutsy swap.
Old Dec 18, 2003 | 08:57 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
no it wont fit right in like you want. get a procharger, they make something for everything. 4.2? why would you even look at that...
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
theurge
Aug 21, 2015 12:46 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
89lsc
Aug 14, 2015 04:58 PM
