350 base HO intake
Old Dec 9, 2003 | 11:43 AM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
350 base HO intake
I was curious what i should go with. It recommends carb but i thought maybe I could throw the holley stealth ram on top. So what would get more power?
Old Dec 9, 2003 | 02:27 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
If your referring to the GMPP 350HO you can't use the Holley steath ram because the 350HO has vortec heads, and the HSR is designed for standard non-vortec heads.
A carburator is a much more cost effiecent solution. An aftermarket fuel injection system will make about the same power a carburated setup does, they just cost about 4 times as much.
As far as i know, there are three aftermarket FI choices for vortec heads.
-SDPC TPI base plate for stock TPI setups
-Edelbrock sells a vortec specfic injection setup.
- and the miniram III will fit vortec heads.
as for carburated intake manifolds,
the edelbrock performer RPM, and performer RPM air-gap are great choices, just make sure you get the vortec specfic manifold
im running a performer RPM air-gap on my 350HO and couldn't be happier with it.
Old Dec 9, 2003 | 03:05 PM
Engine: 305 tbi
Transmission: t-5
If you recommand carb., what carb should i be looking in to, if you don't mind.
Old Dec 9, 2003 | 05:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The HO Deluxe comes with carb, intake, distributor, flexplate, balancer...
Old Dec 10, 2003 | 10:01 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
as five7 said, the deluxe version comes with a carb(holley 600 vac. sec.), and is pre-assembled, takes all the guess work out. but if your going to buy the base 350HO, from what i hear, holley 650 vac sec, or a 650dp would work pretty well. im running an edelbrock 600, and i want to switch to a 650dp, the edelbrock has great street manners, but i think it would make more power with a properly tuned holley.
Jake_92RS
Jan 28, 2020 10:37 PM
Keith5
Aug 27, 2015 04:37 PM
theshackle
Aug 22, 2015 06:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
