ZZ4 with Complete HSR !?! HELP!
Old Jan 4, 2004 | 10:44 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
Ok, so my 350 TPI decided to chuck a rod through the block. BOOOOO!!
Anyway, my cuz has a built ZZ4 but he had a blower on it b4, blower warped form heat and is useless and cant use it. Motor is compelte cept intake and above. Better cam then the ZZ4 and it has WORLD racing heads, port and polished. Strong motor with about 400HP or around there.
I dont have enough money to get the motor and the complete HSR system which is about 2500 bucks. So i was thinkin to make the motor a carb motor, i have the intake and a good carb to feed the motor. This was the original combination b4 the supercharger and it ran low 12's in his 86 Monte SS.
I was wondering how and what will i need to leave alone if i make it a carb so i can later on put the HSR system on, do i need the original harness, cuz it comes with the new PROM. which fuel pressure regulator will work best for the carb. Any info will be appreciated so i can get my *** back on the road as spring hits here in NY. So i can start the ***** diet again.
Or, should i barrow some money from my parents and get the HSR complete system right away and just swap that in first time in. If i do that, whats involved here, what do i need and what i dont need, vacum lines and connections?
Thanx you all..now im out.
Old Jan 4, 2004 | 11:30 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
It'll take tuning, but can't you use the original harness, and ECM? All you need is the HSR base, plenum, AFPR, and Fuel rails. That comes out to about $550. Then add price of motor, and tuning.
You don't need the whol EFI setup, just the manifold, AFPR and fuel rail kit.
Old Jan 5, 2004 | 06:04 PM
Charged350's Avatar
Car: 87 IROC Z28
Whta about bigger injectors, 255 fuel pump, and other ****...cuz this motor wont run good with the 19 pound injectors from the stock tpi, damn, what should i do....
Old Jan 6, 2004 | 03:18 PM
FruityOne's Avatar
Wasn't refering to anything else but the HSR setup.
If you have a TPI then you only need to spend about $550 to get the HSR on your car. As long as all the TPI electronics are still there.
Old Jan 7, 2004 | 06:30 PM
cdartz's Avatar
If your car was an original 350 TPI car then you have 22 lb. injectors. Personally I'd keep your TPI on it for now until you can afford to buy a Stealth Ram. Your stock TPI won't hurt anything, it will just prevent you from getting the full potential out of the new motor.
Old Jan 8, 2004 | 08:24 PM
Charged350's Avatar
Car: 87 IROC Z28
Oh yeah, i forgot i got 22 pound injectors, i can get just the HSR intake for now and hook everything up, but wont i need 24 or bigger injectors to run good, it is a 400 horse motor. But what about the mas airflow sensor, thats gonna limit the motor even more, can i get rid of it( i wish) or how hard is speed density to hook up, or i may just carb it with a 750 i have and rip em...
Old Jan 9, 2004 | 12:43 PM
FruityOne's Avatar
The MAF won't limit you that much. Its not something I'd be worrying about. There are guys running quick times with a MAF system. Plus, the MAF system will be more tolerant to changes in the engine for now.
Old Jan 9, 2004 | 07:39 PM
Charged350's Avatar
Car: 87 IROC Z28
I donno man, that double plane design and that 750 cfm are lookin good on that shelf int he garage, and may look better on the motor....what ya think. so much easier to tune adn no need to **** with electronics forver....old skool style
Old Jan 9, 2004 | 09:44 PM
FruityOne's Avatar
Well if thats what you know how to do, and you don't have to pass emissions then I'd go carb.
The HSR will flow as much as the 750cfm carb though, however it WILL need tuning as it will give the stock computer fits.
Old Jan 13, 2004 | 09:10 PM
Charged350's Avatar
Car: 87 IROC Z28
I know all about it, carb tuning and the HSR intake, but emmisions, hahah, in NY they are pretty ..uhh....gay to say the least.
But i donno, carb is looking good now, maybe ill swap down the road again.
RyanJB
May 7, 2016 06:23 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
86CamaroDan
Sep 29, 2015 10:08 PM
MORREALE5
Sep 13, 2015 09:01 PM
355tpipickup
Sep 4, 2015 05:32 PM
