Fuel pump intall before or motor mount?
Old Jan 12, 2004 | 07:51 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Should I install the fuel pump before the engine is in the car? I am worried about the motor mount bolt not having room to slide in. It has been 1 1/2 years since I took them out and I cant recall if they slid in from the front or the rear. If it doesn't matter the nut and a wrench will still fit.
Old Jan 12, 2004 | 08:11 AM
ede's Avatar
ede
been a while but i think i installed the fuel pump before installing the engine in the car. worse can happen is you have to pull the pump back out.
Old Jan 12, 2004 | 09:21 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should have adequete room either way. If it does get in the way it is in an easy spot to remove.
Old Jan 12, 2004 | 09:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The right-hand motor mount has the nut captivated in the upper shell; and its bolt goes in from the rear.
The left-hand one uses a bolt and a loose nut.
Leave the fuel pump on, it will not be in the way.
Old Jan 12, 2004 | 03:01 PM
MCas7's Avatar
In my opinion, the fuel pump is one of the easiest things to install on the engine, why not just leave it off and not have to worry about if it will be in the way? Then you can just put it on after the motor is in. Plus, if you are upgrading to an aftermarket fuel pump, there is a chance that the ports may need to be rotated anyways.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Elliswon
Aug 10, 2015 12:33 PM
